Tết Ant Khang
Tết Ant Khang
Hướng dẫn chạy dead phone bằng Phoenix
ahkiem32
6/11/2010 1:15Phản hồi: 99
99 bình luận
điều quan trọng là các bác deadphone phải sử dụng bản firwave mới nhất mới cứu đc. hôm mình làm mãi ms biết..haiz..
Kon E71 RM-346 CUẢ mình up FW bị lỗi, bây jo up lại nó hiện ra ntn:
Flashing started
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
--- Press phone's power button! ---
Loading update server code: 2080457 bytes
Update server loaded
ERROR: Unable to detect device 0x8401F145. Check USB connection!
ERROR: Failed to set phone to flashmode
All operations completed
Product flashing failed
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Error 0x84009427 communicating to phone. Unable to verify comm.
ERROR: Unable to detect device 0x8401F121. Check USB connection!
Product flashing failed.
Lúc sau nó hiện cái bảng viết:
The flashing failed. Do you like to retry the flashing?
HRESULT 0x8401f121 (-2080247519)
Flash: Communication with phone is not possible. Unable to detect phone operation mode, cannot continue..
là lỗi j vậy?chủ thớt giup minh với...thanks
@letheduong bạn kiểm tra lại USB xem. Mà bạn flash bằng phoenix hay jaf thế?
@letheduong cái này mình cũng đã từng bị. bị lỗi này là do bác chạy bản fimware cũ quá, muốn hoàn thành thì bác phải chạy bản mới hơn bản đang dùng. mà tốt nhất là chạy bản mới nhất lun đi bác.
mình up bản mới nhất đấy? mình đã up bản này 1 thời gian sau thấy máy hay bị đơ nên up lại, ai ngờ lại ko đc, có đồng chí nào rảnh jup mình Up qua teamview dc ko? nick yahoo cua mình: stileboy_1989, đt: 0975557516. cám ơn trước nhé! hjhj
mình up theo hướng dẫn nó báo ntn:
Flashing started
Backup not required
Flashing phone
Initializing
rồi hiện ra 1 bảng thông báo:
Flash: Boot rom was not detected after phone boot up. Unable to start flashing.
MINH ko hieu?
minh dung NOKIA N97 (RM-507) , minh thu may lan rui ma cuu ko dc . cac bac giup minh voi.thanks
@mi19 Chạy bằng jar đi bạn ơi. Của minh la RM-505 chạy bằng jar mấy bản CFW của bác Ntv_79 bản nào cung ok hết. Mà bạn cũng kiểm tra lai cap USB và chân chạy tiếp xúc nữa nhé. Trc mình bị hỏng cap chạy thì có lúc báo lỗi như thế.
Sent from my LT28i using Tinhte.vn
N9 flash bằng phoenix thế nào ạ mọi người ai rảnh chỉ giúp mình với.
nick yh mình đây ạ : who_gone_stop_mehah
Up fw 0r cứuu deadphone = phoenix rất tốt....còn làm bằng jaf thỳ dễ bị deadphone lắm
cám Ơn anh nhiều quá..máy em sống lại rồi 😁
Ở đây có bác nào update fw cho N73 me mà bị died không ? mình cũng đang bị tình trạng như vậy, đã thử phoenix các cách và em nó vẫn nằm im một đống, buồn thúi ruột đây, mong cách chỉ giáo ! thanks all !
và đây là tình hình em nó !
có ai cứu giùm kg ?!
giờ máy e bật nguồn k lóe sang nũa,sạc cũng k vào,ai giúp em với,em cần sưa máy gấp.hình anh của nó khi chạy fw:
hôm qua em cũng vừa thử nghịch ngu flash lại máy nhưng đang giữa chừng bị lỗi, flash lại thì nó hiện Phone failed to boot in flash mode CMT... (em flash bằng JAF ) Bây giờ bật máy k lên, cắm sạc cũng k nốt vậy có phải máy em đã thăng rồi không @@
có lóe sáng không bạn ơi?
hqchung
hay quá, mình đang tìm hiểu :d
p1n3
tháo pin làm gì,mình chỉ cần làm theo cách của chú minh =hướng dẫn chi tiết này http://www.tinhte.vn/threads/940435/ (cũng giống cách topic này nhưng khác bước cuối)
Thì chả bgiờ cần lắm thao tác nthế mà lại tối ưu đc phonix,dễ kinh khủng.các bạn tham khảo nhé.chạy cả FWC hay gốc đều ngon ơ,chả phải tháo thiếc hay cài gì lắm cả
Máy bạn nào die thì tháo pin ra lắp lại rồi flash lại theo cách chú minh thì chả bgiờ chết đc,mình mún nó chết đây mà nó chết đâu .
@p1n3 up fw thấp hơn xem =))
up thử rom máy khác xem =))
rồi đang up rút dây cáp ra xem 😆
thiếu gì cách biến máy thành cục gạch
p1n3
@hung160990 xl bạn chứ m mún dùng mới chẳng đc sao phải đi lùi với thời đại ==))
-máy nào cũng chơi đc hết nhé(đã là symbian)
-t rút cáp đây có sao đâu,chưa nói chú minh bên topic còn rút trăm lần die lên die xuống còn chả sao.bạn còn sợ nó hỏng thì ko bgiờ flash đc đâu vì nó chả bgiờ hỏng đc trừ phi nó die phần cứng =))
@p1n3 xl bạn nhé, mình cũng từng làm cooker rồi 😆
up cũng chưa bao h bị chết cả.
Nếu làm đúng nguyên tắc thì k bao h sợ die cả
còn muốn lùi thời đại thì tùy trường hợp.
vd như fw mới k chưa hỗ trợ tiếng việt, muốn về fw cũ chẳng hạn
còn từ fw cao hơn về fw thấp hơn trên lý thuyết là không thể nhưng thực tế vẫn có cách port ra để về fw cũ hơn
đấy là bạn nói muốn đện thoại chết mà chưa được chết nên mình nêu 1 số cách trên lý thuyết
mà máy thành cục gạch là nó hiện lên imei có dạng 012345678901234 nhé
nhưng mà vẫn có cách câu lại imei được ( ra hàng nhé )
thanks phát đã làm dc 😆)
vậy là không có ai làm con 73me nhỉ ! giờ em nó vẫn nằm yên nghỉ !
Bác chủ thớt có thể cho e xin bộ FW cho 6700 đc ko ạ 😔
@tuan.yfc cái đấy dùng navifirm tải về là được bạn nhé!
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
P-key nokia module version 01.02
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.172.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-78\
Searching for default location of ini...
Checking path: \Products\RM-78\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm7830006.430.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm783006.43.ppm_c
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm7830006.43.image_ora_fr
Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkish,Portuguese
Detected P-KEY: 90009699
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 02.31.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting...........................................................Loader Sent!
Stage 3 starting..........Phone prepared OK!
Waiting for the phone to boot...
PRESS POWER ON NOW!
Using 06.02.002
mình bị lỗi như vậy là sao các bác nhỉ đã thử cả jaf và phoenix mà vẫn k đc m dùng 6280 up fw bằng fw cook do nafim đóng cửa có bác nào có fw 6.43 gốc cho e xin e xin cảm ơn
lam theo cac yeu cau cua phoenix ma van khong duoc toan bi loi.co cach giai quyet nao khong
