Power Control Plus (widget) v2.5.1
Requirements: Android OS 2.1 - 2.3
Overview: Power Control Plus is a widget that lets you turn on / off almost any setting on your phone, right from your home screen.
Features:
- 7 different widget sizes, including vertical widgets
- 9 different indicator light colors
- Over 30 settings available to toggle (list below)
- Power Control Plus doesn't run in the background, to save battery life
- Edit your widget right from the home screen
- Change background transparency
- Add labels to buttons on the widget
- Add a shortcut to any app on the widget
Full list of settings you can change / toggle:
- Wi-Fi
- Airplane mode
- Flashlight (Android 2.2+)
- 4G (WiMAX, EVO 4G only)
- GPS
- Silent mode
- Auto-rotate screen
- Vibrate mode
- Vibrate and silent mode
- Bluetooth scan for devices
- Brightness
- Brightness (triple)
- Screen timeout
- Auto-sync
- Wi-Fi sleep policy
- Sound effects
- Haptic feedback
- Bluetooth discoverable
- Keep screen on while plugged in
- Open shortcut
- Input method
- 2G - 3G (only a shortcut to the settings screen)
- Battery (meter, and a shortcut to Battery Use)
- Scan SD card
- Quick Boot / reboot / power off
- Silent mode (and mute media)
- Lock screen
- Wi-Fi tethering (Android 2.2+)
- USB tethering (Android 2.2+)
What's in this version:
New features:
Full support for Android 3.0 (Honeycomb)!
Honeycomb only: toggle settings directly from the notifications bar, instead of the popup
Improved UI for "Configure Button" dialog
Notification bar widgets have an icon on notifications bar
Bugfixes:
Fixed many bugs with the notification bar widgets; they should be fully working on ALL phones now
Fixed "Change color" button incorrect text color bug
Live wallpapers now appear properly on the configure screen
DOWNLOAD: Download s251.apk with Mup5
