Du Battery Saver+Switch Widget v3.4.0.pro mới I:Tăng thời gian pin từ nửa ngày lên 4 ngày k nói ngoa
pretty.boy70
3/3/2013 5:12Phản hồi: 185
Để tên bài như thế thật là khó tin phải không các bạn?! Nhưng đó là sự thật & mình chẳng nói xạo...nếu bạn không tin thì mời bạn vào user review trên gg play xem họ bình luận thế nào rồi download về cài trải nghiệm rồi hãy ném đá chủ topic nhé...​
Donald Phillips - January 21, 2013 - Galaxy Precedent with version 2.1.0.pro
As Avertised!!
Great App! Is it possible to report just what apps are doing when they launch themselfs univited?? Thanks
Spam
https://lh6.googleusercontent.com/-myBH5qSynqE/AAAAAAAAAAI/AAAAAAAAAIo/TOKtDvmoCAY/w48-c-h48/photo.jpg
Olivia Williamson - February 21, 2013 - Samsung Galaxy S2 with version 2.1.0.pro
Brilliant
Extending my phone's battery life from an average of one and a half days to an average of 4 days, this app does exactly what it promises, quietly and perfectly.
Spam
https://lh5.ggpht.com/RREE0f2gSFRq9Yi_umALXt_ML6nJbTYJ6TEsCJg-75c1TUjH4nqP0KNfOsDqxaa_CqY=w48-c-h48
David Cruz - February 3, 2013 - LG Optimus One with version 2.1.0.pro
Very Accurate
I downloaded last night,woke up this morning & my battery seems to not lose life as quickly keep up the good work for further future updates KingCruz
Spam
https://lh6.googleusercontent.com/-DaqGtY5TwZ8/AAAAAAAAAAI/AAAAAAAAANc/yvBVjfETWnY/w48-c-h48/photo.jpg
Cristian Kiss - February 25, 2013 - Version 2.1.0.pro
Error
1. Cant find to add this app to my white list. 2. Don't auto kill applications that run in background after 5 min. Samsung Galaxy Advanced
Spam
https://lh3.googleusercontent.com/-ntSeQZ4ZIOQ/AAAAAAAAAAI/AAAAAAAAAGI/EQNJZ4cZDVU/w48-c-h48/photo.jpg
Ryan Gates - February 25, 2013 - Version 2.1.0.pro
Rooted Samsung Galaxy Note 2
Love the app, works great but the lower cpu isn't working.
Spam
Abdul Aziz - February 28, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Nice thing
Firstly I doubt on this product but after installing it I come to know that it is superb thing
Spam
Huy Truong - February 22, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Fantastic!
I've always loved this app. Quite sad when they removed from the market for a while. When I saw this again, I instantly jumped on it! Does what it says, well done.
Spam
Yessica Lima - January 30, 2013 - Version 2.1.0.pro
Great!!
It's very clean and easy to use, definitely recommend.
Spam
Jignesh Shah - February 19, 2013 - SEMC Xperia S with version 2.1.0.pro
Gives 10% improvement
Good app. Gives 10% improvement. Recommended for sure. I bought paid version.
Spam
A Google User - March 2, 2013 - Version 2.1.0.pro
Excellent
Excellent
Reden Christopher Godoy - February 24, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Great!
This application is my new best buddy!
Spam
https://lh4.googleusercontent.com/-I5G_qVkFBfQ/AAAAAAAAAAI/AAAAAAAAAAA/MqOjRyIPXK4/w48-c-h48/photo.jpg
chootipat ch. - February 6, 2013 - Version 2.1.0.pro
great apps
It can safe battery more than another app.
Spam
kyle gehrig - February 9, 2013 - Version 2.1.0.pro
Good product
Seems to work well on my note 2
Spam
https://lh5.googleusercontent.com/-byuhZlts-Ik/AAAAAAAAAAI/AAAAAAAAAFM/yE85X67bdQk/w48-c-h48/photo.jpg
Haitham Gendi - February 22, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Battery
Good Application. It is worth the money I paid.
Spam
Dat Nguyen - February 6, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Great
should get one for your phone
Spam
https://lh6.googleusercontent.com/-0u9IS6dMllM/AAAAAAAAAAI/AAAAAAAAAIM/guFwlwkdF8w/w48-c-h48/photo.jpg
Andreas Budianto - January 18, 2013 - Version 2.1.0.pro
App
Good
Spam
Bret Barnes - February 26, 2013 - Version 2.1.0.pro
Battery Saver Du + Switch
This has made my battery last for ever. Worth the buy.
Spam
Kamari Denson - January 28, 2013 - HTC One X with version 2.1.0.pro
Good
Great app it really works wow
Spam
PRABHU S SONDESHH - January 29, 2013 - Version 2.1.0.pro
Working good.
Superb app
Spam
Fabian Baird - January 11, 2013 - Version 2.0.5.pro
Great app !! Must try !
3 days with it and it works awesome . With this real app you really save batery , super easy to use it too. Keep it up!!
Hầu hết đa số đều là review tốt...vậy tại sao không download về cùng cài trải nghiệm thử?​
Quay lại app, mình xin giới thiệu vài tính năng chính:​
★ Chẩn đoán pin một cách hết sức rõ ràng & thật là không thể tin được tiết kiệm pin.
★ Chế độ chuyển đổi thông minh: ví dụ
- Điều chỉnh để chờ dài trên mức pin thấp;
- Đi vào chế độ cài đặt trước của bạn theo lịch trình của bạn;
★ Sạc kéo dài tuổi thọ pin. (ví dụ như gợi ý để sạc hoặc khi nào nên cắm sạc).
- Ra mắt Du Battery Saver để bắt đầu sạc khi pin thấp hơn 20%.
- It nhất 1 quá trình sạc đầy để kéo dài tuổi thọ pin.
★ Thường xuyên đóng những app chạy ngầm không cần thiết;
- Thiết lập khoảng thời gian các nhiệm vụ nền làm sạch;
- Cần để lại một số ứng dụng chạy nền? Thêm chúng vào danh sách bỏ qua.
★ Giảm xung CPU khi tắt màn hình (ROOT thiết bị);
=== Tính năng đã có ===
✔ 3 Widgets mạnh mẽ:
- One-tap tối ưu hóa (task-killer)
- Thiết kế pin hiển thị và chuyển đổi chế độ mới
- Công tắc mở tắt cao cấp
Đây là cách tiết kiệm pin dễ dàng bằng cách sử dụng tiện ích pin 1 tap, và kéo dài thời gian sử dụng hơn 15% bằng cách chuyển sang chế độ tiết kiệm pin, cũng đi với 1 tap widget mạnh mẽ.
✔ Tối ưu hóa sử dụng pin của bạn trong 3 chế độ cài đặt sẵn:
- Mode (chức năng cơ bản, đáp ứng nhu cầu tiết kiệm pin bình thường);
- Chế độ chờ (Đóng tất cả ngoại trừ quay số và SMS, kéo dài thời gian pin cho thời gian chờ dài nhất);
- Sleep Mode (Đóng tất cả trừ đồng hồ, tiết kiệm pin rất nhiều trong khi ngủ);
✔ Tùy chỉnh chế độ của bạn, thiết lập bất cứ điều gì bạn thích và tìm hiểu một trong những phù hợp nhất!
✔ Pin chỉ số, pin Cấp% trong thanh trạng thái sẽ chuyển sang màu đỏ khi <20%;
✔ Báo cáo dự kiến thời gian còn lại;
✔ Ringtone nhắc nhở cho tình trạng pin khác nhau;
✔ Chi tiết phân tích điện năng tiêu thụ, không chỉ các ứng dụng, mà còn là phần cứng (CPU, màn hình, cảm biến, WiFi, radio), pin theo dõi chuyên nghiệp nhất (pin thông báo) cho đến nay;
Hình ảnh về app:
Chi tiết:
Link Zippyshare / Kleii / Mega tốc độ cao:
Du Battery Saver+Switch Widget v3.4.0.pro apk (mới nhất trên gg play)
Du Battery Saver+Switch Widget v3.3.0.pro apk
Cập nhật cho anh em:
JuiceDefender Ultimate v4.9.0 mới I+Cách dùng hiệu quả-App tiết kiệm pin "đỉnh" nhất hiện nay!
Tổng hợp app tiết kiệm pin được dùng nhiều nhất trên gg play bản mới I link + cách sử dụng hiệu quả
More app & game trả phí cập nhật thường xuyên click here:
http://www.tinhte.vn/threads/1337665/
185 bình luận
cho link khac di
Link MF của chủ thớt này. mình down về rùi up qua MF thôi. Không có gì đâu @@!
http://www.mediafire.com/?ngd4od5by5qy1g1
tks.
công nhận thấy có chút thay đổi...nhưng chưa đáng kể. thử dùng tiếp xem thế nào...thank chủ top
cứ thanks cái đã
trải nghiệm sau
Bác nào làm cái hướng dẫn sử dụng cho ae đi. Google dịch khó hiểu quá.
Thanks chủ thớt. Để xem có hiệu quả không.
Pretty boy ơi. Em hỏi cái ạ. Em có đọc trên 4rum cái bài không nên sử dụng Tast killer vậy trong PM a đưa. có cái chức năng clean khi clock srceen đó ạ. vậy theo a nên check cái chức năng đó không hay tắt đi thì tốt hơn ạ.😃
@yoseob201209 nếu như máy bạn Ram nhìu thì k cần chọn vào...ngoài ra, có 1 số fần mềm cứ chạy ngầm kiểm tra gì đó đó mà bạn kt trong fần app đang chạy của máy thấy k cần thiết như Chrome,...thì chọn cũng ok...máy bạn kt mà k có ~ app chạy ngầm fiền fức gì đó thì khỏi chọn bạn nhé!
chube_way
12 năm
bản này là bản free sao mà không dùng được mấy chức năng như onekey testing,smart,charging,mình kick vào toàn báo up lên premium
bản này pro mà
nhưng mà ko hiểu sao của mình cài vào tốn pin hơn
máy mình LTE 2 F160S đang dùng rom gốc v20e
chube_way
12 năm
vậy lạ nhỉ mình lấy bản này cài vào máy thì mấy chức năng kia không làm j được nó toàn bắt upgrade.
đã test sau 1 ngày, tình trạng 21 tiếng, giờ còn 40%
==============> không tốn pin hơn, mà cũng không tiếng kiệm hơn bao nhiêu.😃
dẫu sao cũng thank bác chủ TOP nhìu
Máy mình block link ...... :|
Đành phải on PC để down.
https://mega.co.nz/#!hQxH3aCD!LFD0lggEUw6n6C-MTu21shygeCxUp5p0lVt3aDyUF2M
mình thấy cũng tạm ổn, tiết kiệm được tí 😁
wazza7b
12 năm
cho hỏi mình root máy rồi mà ko dg được chức năng lower CPU frenq nhỉ? ai lam đc hướng dan mình làm cái nyaf di
ntminh
12 năm
Gợi ý khi nào để sạc thì nó báo thế vậy bác chủ thớt?cái time left nó ghi ở đấy nghĩa là j vậy bác
Mình mới cài vào, thấy chạy cũng ổn.
Nhưng khi gần hết pin, mình cắm sạc thì không thấy %pin tăng. Để suốt cả đêm vẫn 17%, đến sáng bực quá rút sạc ra (định là gỡ luôn phần mền này để sạc pin). Khi chuyển sang chế độ My mode -> % pin lên 73%, một chút lại lên 85%.
Không hiểu vấn đề này là gì nữa. Có ai giống mình không thế.
Mình xài Sony Xperia Go.
Thanks.
CPU bạn hiệu gì? Nếu là MTK thì chắc là không được. Mình chưa thử setup nó nhưng đa phần các chương trình điều khiển CPU trên app store không dành cho MTK CPU.
voky45
12 năm
CPU của mình snapdragon pro cũng không dg được chức năng lower CPU frenq.Mặc dù máy đã root rồi
