hôm trc đang up fw cho con 2700 bằng phoenix, đang erase 20% mà nó mất điện. h bật nguồn chả thấy động đậy j. up bằng phoenix ở dead phone thì ra thế này
Flashing started
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 14592 bytes
Secondary boot loaded
Loading update server code: 308032 bytes
Update server loaded
Starting to recover the phone
Recoverying phone
Initializing
ERROR: Unable to detect device 0x8401F145. Check USB connection
ERROR: Failed to set phone to flashmode
Unable to set the phone to flash mode. Unable to flash.
có cao thủ nào giúp vs không 😔(
Flashing started
Backup not required
Flashing phone
Initializing
Loading secondary boot code: 15168 bytes
Loading update server code: 825443 bytes
Partitioning....
Partitioning complete
Erasing....
Erasing complete
Asic CMT: Start programming 318370 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic CMT: Programming data sent: 100%
Programming complete
WARNING: Asic CMT: NAND status reported bad blocks
Asic CMT: programming succeeded
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Recoverying phone
Initializing
Error 0x8401F121 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
Phone recovery completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Failed to verfy communication to product
Đến đây thì nó hiện bảng báo Fail...help mình với
minh mới vào nghề chẳng dc học hành cẩn thận . tự làm tối qua có em c5-03 khóa mật khẩu chậy thông thưởng chẳng được . báo lỗi hoài hôm này xem bài này cái chạy ngon ơ. mà biết thêm dc 1 số cách để xử lý . thanks
bạn ơi. con 2730 của minh đang chạy fw = phoenix thì mình rút ra tại lâu quá. thế là mình ấn nút đỏ không nên tí nào ( đen xì luôn, không có màu trắng nhé). rồi mình down bản khác về và flash thì đến bước này
Flashing started
Backup not required
Flashing phone
Initializing
thì nó không chạy nữa vào báo làm lại. bác có cách khắc phục không a? hay là chết main?
mình làm được rồi . các bạn làm theo mình đảm bảo ok
thứ 1: tải fw của nó về . cho vào product
thứ 2: bat phonenix chon open product chon fw đó . phần connection ( chon NO CONNECTION )
thứ 3: bật flashing chon fw update . chọn bản fw và nhớ TÍCH vào ô deal phone .
thứ 4 bấm refu cắm cáp bật nguồn chạy
ok vậy là mình làm được
em co cai dt nokia classic 2700 Rm-561 đang dùng 9.97 nên em up lênh 9.98 nhưng sau này mới bik là ko có tiếng viêt nên chuyển lại sang 9.97 làm môt hồi mãi ko được nghĩ sao ko bik bâm vào phần dead phone rồi chọn phần mền 9.97 rồi bấm refurbish và bị lỗi sau này mới bik là ko đc cài bản thấp hơn cho điện thoại giời khởi động thì ko lênh dead phone thì tham khoả môt số trang rồi nhưng làm mãi ko đc đẻ ít bữa em up thử mong các pro giúp cho
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
4. Insert Charger to device
--- Press phone's power button! ---
pé 6500s của e bị dead bấm nguồn không lên dùng Phonex chỉ chạy tới đây rùi báo Retry
Loading update server code: 294144 bytes
Update server loaded ai giúp e 😔(
