Solar charge : sạc pin năng lượng mặt trời cho 8700
cuong205a
15/8/2008 16:19Phản hồi: 8
vì một thế giới toàn năng lượng sạch
http://www.blackberryinsight.com/wp-content/uploads/2008/07/solar-charger_blackberry-curve_1.jpg
http://www.blackberryinsight.com/wp-content/uploads/2008/07/solar-charger_blackberry-curve_2.jpg
http://www.blackberryinsight.com/wp-content/uploads/2008/08/solar_charger_blackberry_black-grey_8700v.jpg
http://www.blackberryinsight.com/wp-content/uploads/2008/08/bb_solar_charger_8700v_flattened.jpg
http://www.blackberryinsight.com/wp-content/uploads/2008/07/connecters2.png
đạc biệt, thời gian test thử nghiệm cho BB8700v chỉ có 94 phút : http://www.blackberryinsight.com/2008/08/15/solar-charger-with-flattened-blackberry-8700v-real-life-test-charging-from-0-to-100/
TÍNH NĂNG
  • Li-ion Battery Charge Time (Solar): 8-12hrs
  • Li-ion Battery Charge Time (DC/AC): 2hrs
  • Connected Device CT: 2-3hrs
  • Built in LED light
THÔNG SỐ KỸ THUẬT
  • Solar Panel: 5.5V/110mA
  • High Capacity Li-ion Battery: 1300mAH/3.7V
  • Output Voltage: 5.5v.
  • Output Current: 350 at 1000mA
  • Operating Temperature: -20 to 45 degrees
  • Measurements (mm): 95 x 63 x 14
  • Weight: 76g
TRỌN GÓI gồm:
  • Pocket Solar Charger TC004
  • USB Cable
  • 8 Device Adapters
  • AC Power Supply 100-240V
  • Charge extension cable
Supported BlackBerry® devices: 71xx Series, 713x Series, 72xx Series, 75xx Series, 77xx Series, 81xx / Pearl Series, 83xx / Curve Series, 87xx Series, 88xx Series, 90xx / Bold Series
You can get the Solar Charger for BlackBerry for just $29.95 at 100milligrams.
http://www.blackberryinsight.com/wp-content/uploads/2008/08/solar_charger_blackberry_black-grey_box.jpg
http://www.blackberryinsight.com/wp-content/uploads/2008/08/solar_charger_blackberry_black-grey_box-open.jpg
8 bình luận
hay quá,nhưng mà mắc thật giá như nó 2 3 trăm thì ok ngay
cái này bán đầy với giá 250k, rao trên muare lâu rồi mà
Hix...đâu đâu cho link cái, mua về dùng cho nó sành điệu...😁
cái này dùng có phải phơi ra nắng ko nhỉ, tiện cái là đi du lịch dã ngoại mang theo các bác nhỉ. Bác nào dùng rồi thấy hay ko chia sẻ ae tí đê:happy8se:
Cũng hay nhưng hơi bị chát. May em đi đâu toàn mang xách tay nên lúc nào rỗi thì cắm luôn. Đỡ được khoản nào hay khoản đấy chứ cái đt đểu đểu đồ phụ kiện còn nhiều hơn cả tiền mua đt thì chơi phu kiện đâu phải điện thoại 😔
tui có hàng
tui có hàng này 186k bảo hành 3 tháng ai cần liên hệ tui 0915721229 cần tìm đại lý giá ưu đãi
29 USD là hành chính hãng thôi. còn hàng China thì...
Cũng hay nhưng mắc quá thôi thì chờ đến khi nó rẻ vậy.
