TTBC2024
TTBC2024
[Tuyệt đẹp] Light Flow - LED&Notifications v3.14.101 Apk
harvard2040
26/1/2014 3:49Phản hồi: 1
Bạn sẽ ngạc nhiên sau khi cài Light Flow - LED&Notifications lắm đấy.
Thanh thông báo trên your phone của bạn sẽ không ĐỤNG HÀNG với bất kỳ chiếc phone nào khác. Và khi đó chiếc Phone của bạn là duy nhất, độc nhất vô nhị. Think Different !
Description:
[Change24h.net] Light Flow allows you to take control of your notification LED colors and makes them successively flash one color after another.
It also allows you to set repeating sounds on vibration patterns for you notifications. You can also set a "sleep" mode or "on charge" where the lights and/or sounds and vibrations will not be heard or seen. If you've come from a Blackberry device and miss the features of BeBuzz / BerryBuzz then give LightFlow a try!
This program will allow you to control the notification color for the over 600 applications and system events such as:
* Missed calls
* Voice mail
* Calendar reminders
* gmail
* email
* SMS messages
* MMS messages
* Low battery
* No signal
* Google talk
* Facebook
* Twitter
...and many many more
See our website for a full list of applications supported:
http://www.folioflow.com/ff/page/website/lightflow/pageId/1687
It allows the colors to flash in succession, so if you have a new SMS and a missed call it can alternate between the two colors. You can also set which notification type has the highest priority and let it flash in just that one color.
It'll even push notifications out to your pebble smart watch, Sony smart Watch and the DashClock lock screen extension.
For a full changelog see here: For a full changelog see here:
https://www.folioflow.com/ff/page/website/lightflow/pageId/1693
For a full list of permissions required and why see here:
http://www.folioflow.com/ff/page/website/lightflow/pageId/2277
Known issues/Limitations
Samsung phones when accessibility is enabled may cause the phone to start talking, warnings about air view and a few other issues. These are confirmed samsung bugs (see here: http://developer.samsung.com/forum/board/thread/view.do?boardName=GeneralB&messageId=204387) but the app can be run without the accessibility service and still work (but with a reduced notification list)
Not all phones support all colors.
For example: Most HTC phones only support 3 colors and require "Rooting" and running the app in "direct mode"
Some phones can only light up the notification while the screen is off.
Some phones cannot have their notification light always on
Some phones cannot have their notification blink and it will always be on
Note that it will take over control of your notifications and you will therefore only get notifications for categories that the app allows.
★ We recommend you try the "lite" version first before purchasing to avoid any disappointment if it doesn't work for you. Some phones require root privileges to access the LEDs. ★
★ For the differences between this version and the lite version see here: http://www.folioflow.com/ff/page/website/lightflow/pageId/1687
★ If after updating you have problems we recommend you reboot your phone ★
** Most HTC phones require "direct mode" setting. Most gingerbread builds for HTC phones require root access due to HTC changing the permissions on the LED control files. **
** If upgrading from the "lite" version, please uninstall the lite version first but you can backup and restore settings between versions **
Smart Connect extension for SmartWatch 2
LiveWare™ extension for SmartWatch
New Feature:
3.15.103 (currently in staged rollout to 20% of users)
- Large memory and stability improvements
- Sony Illumination Bar support
- Sony SmartWatch support
- Led brightness control while in sleep mode
- Control of button backlights on the LG G2 (root users only, see website for details)
- Switch screen on option working on S4
- Support for an additional 80 apps.
Many more changes
See full change log here: www.reactle.com/lightflow/changelog
3.15.104
Bug fixes and updated translations
Tags:
Light Flow - LED&Notifications 3.15.104 Apk, Light Flow - LED&Notifications Apk, Light Flow - LED&Notifications v3.15.104 Apk
Download:
Link download from Change24h.net:
Read more: http://www.change24h.net/2014/01/light-flow-led-v315101-apk.html
1 bình luận
Ứng dụng này ko phù hợp với một số máy bạn nhé
Sent from my GT-N7100 using Tapatalk
